Equal constraint in sketcher?
I have say a rectangle with each corner having a radius.  I'd like to put one dimenson on the radius and then set the other 3 radii equal to this one.  Ala Pro/E style I would just add an equal constraint to each of the three radii and I'm done.  Not possible in Catia w/o creating a formula for each?
V5R14
Thanks...
RE: Equal constraint in sketcher?
Did you know you can select the points in multiple corners and then select the "Corner"(fillet) icon. This automatically creates the formulas in a sketch.
You can also use the Equivalent Dimensions icon.  Using this method, changing one dimension in the set changes the others.  It depends on your design intent you may only want to have one driving dimension.
