Applying DRAFT -----ALOT!!!!!
I have a hexagon pattern that I need to add taper to.
The model is unparameterized model. The hex is 5mm wide and 2.5mm deep. The problem is that there is about 500 of these hexagons that all need draft. A number of other features that will not be drafted also have the same A and B surfaces as the hexagons.
Other than picking the 3000 surfaces individually what is the best way to apply draft?
RE: Applying DRAFT -----ALOT!!!!!
Send it back from where it came from and demand these guys to add the draft!
Can you reproduce the pattern?  If so, can you fill in the existing hexagons & make your own with draft & then re-pattern them?
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
