SolidWorks drawing to DXF export problem
Hi All,
When I export a solidworks drawing as a .dxf file. The Arcs and Circles in the solidworks drawing are replaced by a series of small flats following the contour of the line. Is there anything I can do to avoid this problem?
Our CNC machines are running Mastercam 8.1 and read the .dxf files as their input.
I have heard of Mastercam direct for solidworks, does this avoid the problem?
M-J
M-J
RE: SolidWorks drawing to DXF export problem
If I don't use the "regen" command the circles will look like octagons, and they will be read that way by our machines. Use "regen" and they all turn into circles.
Best Regards,
Heckler
Do you trust you intuition or go with the flow?
