Updating Standard Views
In the "View Orientation" dialog box, I can't seem to "pate Standard Views". Does anyone know how to fix this problem or get around it?.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Updating Standard Views
1) Orient your model the way you want it
2) push the space bar
3) Highlight the view you want your model to be at
4) Click the middle telescope.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
I've been having the same problem. I have discovered that if you try it several times in a row eventually it works. No idea what causes the problem, but I have observed that when I click on the update button I can see the highlighted choice jump back to the present view just before the dialog box disappears and no update takes place. I too have only seen this problem since loading 2005. I happened with SP0.1 and SP1.1 At least now I know I am not alone with this problem.
Timelord
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
