Experience with UAA2016 chip?
Does someone have experience with the UAA2016P chip?
I'am trying to regulte a shaded pole motor.
In the end it should be the meaning the control the speed of the motor in function of the temperature.
It would be a great help to have some feedback, it would be helpfull.Thx in advance
RE: Experience with UAA2016 chip?
nobody?
The reason that you do not get any answers might be that no-one have used that part for speed control.
It is not designed for that purpose. It is designed to switch heaters on and off and there is no possibility to make it control the firing angle continuously in order to change the speed of the motor.
I have used obsolete chips like the TDA780 for that purpose, but we now use little PIC processors to do the same job. The loads are mostly little fan motors and we control the speed from almost standstill to full speed. The PIC also does heat and humidity measurement and control.
Thanks for the responce.
The motor I need to control is a 230V motor.
I'am new with all this stuff so any info is welcome
THX
My boss doesn't wonna buy complete modules.
So i'am looking to design something I can put toghter easy.
Allready thx for the info.
