when import .exp file in V4 missing all text and dimension
I have a . exp file, when importen this file, in catia V4 missing all text and dimension.
I atacch some esemple from .log file
CIM032110 - INFORMATION IN CATIMP_SOFTWARE :
ANNOTATION DESCRIPTION NUM.ARAD
FROM CATEGORY 2 AND NUMBER 9
ALREADY EXISTS IN RECEIVING PROJECT FILE
CIM030310 - ERROR IN CATIMP_SOFTWARE :
DESCRIPTION POINTER NUMBER 48 FROM
CATEGORY 3 THAT WAS REFERENCED
WAS NOT FOUND IN CORRESPONDENCE TABLE
CIM030330 - INFORMATION IN CATIMP_SOFTWARE :
FUNDAMENTAL DESCRIPTION NOT FOUND IN
RECEIVING ANNOTATION DESCRIPTION TABLE
CIM030355 - INFORMATION IN CATIMP_SOFTWARE :
CURRENT STATE ELEMENT DELETED
CIM032205 - INFORMATION IN CATIMP_SOFTWARE:
ANNOTATION ELEMENT DELETED
FOLLOWING DELETION OF CURRENT STATE ELEMENT
thank you
Marian
thank you
Marian
RE: when import .exp file in V4 missing all text and dimension
A quick fix is to select all text and dimens with *annd and then change the font and text size to something that you normally use.
www.micro
