Earthing
Earthing
Is it a good practice to bond the Earth of the Genset and the earth of a surge arrester connected to the utility mains. Could that be the possible cause for the burning of control boards and UVRs?
RE: Earthing
In NEC (National Electrical Code, US) installations the answer depends on the type of ATS, that is, whether the ATS is 3-pole (solid neutral), or a 4-pole (switched neutral).
By the National Electrical Code, if you are using a 3-pole ATS, then you must have a solid neutral and must ground the generator frame through the service equipment (i.e., o/c device used to terminate the utility connection--I don't know the UK term). Do not drive a separate rod at the generator in this case.
On the other hand, if you are switching the neutral with a 4-pole ATS, then you need a separate ground rod at the generator. Although the NEC handbook diagram (Figure 250.7) does not show one, you will also have a separate service disconnect for the generator ahead of the ATS (usually the generator CB), unless the ATS is service-rated (it will have a CB in the cabinet). In the US, service equipment must have a label on it that says that's what it is.
The advantage of the switched neutral is that you can use a GFP scheme when on backup power. With the s/n, you only get GFP on utility, because the main bonding jumper is at the service equipment, which is switched out on backup.
Wm
RE: Earthing
Thanks for the post.
