SAP2000 Question
SAP2000 Question
Hi
How can I intruduce to this program, a combind section?
I mean for example, how can I tell the program in the analisis of a truss, I want to use 2 angles and one channle in the bottom chord and 2 angles and 2-22m rebars on the top chord?
would you please help me
RE: SAP2000 Question
Are you trying to model a truss as a frame element? Are you trying to somehow weld members along their length to give a kind of a composite section?
If you are trying to do either of these things, I don't believe SAP has the capacity to do it automatically. SAP has a database of standard sections, but does not have the capacity to form these into new composite sections.
The only way I can think of to build a composite section out of the standard section database is to actually model the individual components of the section (ie each angle and bar) along their respective centerlines. This will give you a series of parallel frame elements for each composite member. You should then constrain the relevant joints together to ensure the member acts compositely.
Hope this helps.
Michael
In Multiframe you just draw in Acad the combined section and import the *dxf in SectionMaker choose the material, install the new section and save the new library.It will be avaliable in Multiframe. It can´t be easier
Exactly that is what I mean. I want to make a composit section for my truss or let assume for any kinds of other structure. I remember from data entery for SAP90 we had to write all the blocks of information idividually on a dos format like PE2 and then give the program as a data entery file for analysis. so in that case we could intruduce to the program, Composit section as well by giving him, cross section info.
but now with this new technology and software, I thought it should be other way or easiest way to do that!
Any way, I am appreciate of your respond and hope you can help me in this case too.
Amir
I think the SAP2000's manual or someone at Berkeley can help you, but I think that there was a *.exe file that I saw a friend using that performs some calculations for your needs. Sorry I don't remember the right arguments for using it.
The advantage of Multiframe becomes more evident when we need to input data from our customers directly from the cad files, avoiding creating layers and splitting the entities around them
Hope you get your goal.
Michael
