Coefficient of Friction of Rubber on Aluminum/Steel
I can't seem to find any COF number for rubber on aluminum or steel. All the tables I can find seem to ignore those two combinations.
Does anyone out there have any experience or a source that can help me answer this question?  My application is a truck tire on a flooring plate in a factory and the temporary plates construction workers put on roads when they are working on roads.
Thanks for your help in advance.
RE: Coefficient of Friction of Rubber on Aluminum/Steel
It is very dependent on the surface conditions. For safety's sake use the entire range .005-1.0, taking the worst value for each case.
Cheers
Greg Locock
