Title Block?
Title Block?
Im trying to drop a title block in. Any suggestions on how to do this? Thanks
Paul
Paul
RE: Title Block?
This is just a work-around, but it seems to work for me just fine. What you can do, if you have a title block already, is create a new view inside the drawing you want the title block in and then copy it from where it is saved into this new view. I know there is a way to actually put the title block in the background but I have not gotten that far yet. Make sure to create an entire new view and it will be easy to move its position on the sheet. Also, make sure that the view you want to paste into is activated before pasting.
If anyone knows how to set a title block into the background, I am interested to hear how it works.
Hope that helps, BT
RE: Title Block?
Have a look in the database of catiaV5forum.com [link ht
Check the online Doc there is one there...
Eric N.
RE: Title Block?
inside drafting workbench go to edit/background
then an icon will appear on the "drawing toolbar" that is the frame creation icon. If you hit it then a new window will appear allowing you to creat edit or delete a titleblock. It automatically creates it o the size of the page etc.. puts the user name, drawing number date and weight automatically In catia you have two or three allready defined, and if you are brave enough, you can edit the macro that generates them, and personalized them for youself. We did and its quite easy.
Hope it helps
RE: Title Block?
Try File/Page Setup, pick Insert Background View then browse to your titleblock. It has to be a CATDrawing so if you have a titleblock in DXF or DWG import first it then save it.
RE: Title Block?
