Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...If there has ever been a justification needed for access to the net during working hours, just referring to this site should suffice. Fantastic!..."
Geography
nhtrikes (Computer)
3 Mar 05 13:56
Nephew's notebook stopped working. Wouldn't past post. Removed all hardware and turned computer on. Both fans wouldn't turn on but light on MB. Removed processor. Both fans turned on. Replaced with new processor. Same results. Fans don't work with processor in socket but work when processor is removed. Replaced MB. Same scenario. However, sometimes I can get the fans to turn on when I turn the computer on with the processor in the socket but turn it off quickly as I can feel the heat spreader getting very warm quickly even with both fans running. Seems to get too hot. After it's turned off and turned back on the fans will not come on again until I remove the processor. So is it the processors or the motherboards that are causing the short? Very frustrating. Haven't even attempted to attach monitor or HD or any other hardware until I can get the motherboard to at least come on without overheating the processor. Have never seen this type of problem before. Any suggetions very welcome. Thank you.
BradTh (Computer)
5 Mar 05 13:19
Sounds like the motherboard is fried. The motherboard is probably shorting out processors that you keep replacing. Is the RAM installed right now? Have you tried turning it on without the RAM in. Your laptop will make an annoying noise without the RAM in it, but give it a try and see if that does anything. Otherwise I think its a fried motherboard.
Close Box
Join Eng-Tips® Today!
Join Us             Close
