Trouble splitting a BOM in 2005 ?
Has anyone else had trouble splitting a BOM in 2005? I can split the BOM fine, but when I try to drag the split portion to a new location it does not work properly. I can pick up and drag the split portion, but, when I try to drop the split portion it jumps back to the location I was dragging from. However, if i try to click on the split portion to drag it again I am able to click on it. After some frustration I found that if I click in the area where I origionally drag the split portion, I could move activate the BOM again. This seems really weird, has anyone else had this issue?
Thanks, James
Thanks, James
RE: Trouble splitting a BOM in 2005 ?
Previous SW versions placed the split either side of the main BOM.
Eng-Tips.com Forum Policies FAQ731-376
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
What SP are you on? I've got 1.0ev still loaded and can move the split portion without problem.
Since it is showing in the old location but acting as if it is in the new place, it could also be a graphics issue. What video card and driver are you running?
I think you will find that it is actually 2 seperate BOMs.
I am running SW2004 & cannot see any way to move a split BOM portion, other than Left or Right of the main section.
To move the split portion, make sure you "grab" the Blue band at the top of the section.
I think it could be the graphics, because I can move the split section fine, it just won't graphically stay where I place it. Solidworks seems to "think" that it's where I placed it, but it doens't show up that way.
5.12.2195.3056 for Win2K
6.12.10.3056 for XP
