Pharma Valves for high pressure
I´m looking for a ball or any kind of valve, that should be welded onto a 6mm by 1mm wall, with a trubore of 4mm, and with a max inside surface finish of less than 0,5Ra.
Max working pressure is 100 bar.
Any ideas where to find such valve, the application is HPLC.
RE: Pharma Valves for high pressure
- http://www.rubvalves.com ;
- http://www.4gghidini.it ;
- http://www.cimberio.com/ing/home.htm (Products > ball bibcock and mini ball valves);
- http://www.parker.com/Products/EPD/
- http://www.swagelock.com/ .
Bye, 'NGL
I know for a fact that a company called Ball Valves UK do this spec of valve, although I'm not sure about the 4mm bore.
Tel +441162727300
Fax +441162727345
e-mail sales@econosto.uk.com
You need their "RP" series valve.
BVMAN
Like APV, BBS SYSTEMS, aLPHA LAVAL, eUROBINOX, SUSMO
