attenuation-distance-frequency
My name is Martin Aureliu and i'm quite new in the radio communications field.
I know that the propagation losses vary with distance having the frequency as a parameter but I don’t manage to find an appropriate chart for this.
Could you please tell me where may i find a chart for distance - attenuation - frequency relationship for VHF and UHF?
Thank you!
RE: attenuation-distance-frequency
Martin,
As I recall, the formula is 34.4dB + 20 log10 D + 20 log10 F. = Loss
D is in Kilometers and F is in Megahertz
This will give you a propagation loss figure in dB.  To this you should add your transmit power in Dbm, your antenna gains and any co-ax or waveguide losses.
Together these will give you a figure for the received power at your receiver in dBm.  If this exceeds yor receiver's minimum sensitivity, you will probably, repeat probably, have a good  link.
This also assumes a clear line of sight and no reflective fades or other Freznel zone nasties.
Directional antennas improve performance markedly, with the gain of a dish antenna actually increasing as your frequency increases, offsetting somewhat the 20 log10 F term in the propagation loss equation.
Hope this helps
John
Question about microwave line of sight antennas. Probably easy to some.
Why do you think the shape of microwave antennas made like a drum? I know that a certain material need to enclose the feed for protection due to harsh environment but why like a shape of a drum?
Any ideas?
