Drawing - link properties?
hello all,
few questions:
On the link properties icon, on the drawing sheet layout
is it possible to link properties from the BOM,ie item mumber and quantity to
automaticly generate on the drawing sheet layout.?
Also on the link properties icon on the drawing sheet layout
when picking SW-Forlder Name. The full directory of all the folders appear
is it possible to select only one folder.?
Callum
www.minis4monkeys.co.uk
few questions:
Callum
RE: Drawing - link properties?
Can you give a better explanation as to why you want to do this?
for your second question I belive the property "SW-Folder Name" is going to display the full path of where that is located on your network/harddrive. If you want fewer folders to show you may have to re-structure your file folders.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP1.1
I always do that. I type in a note with the part number in it. But for the part number (which here is our file name) I click the link properties button and select SW-file name. That way if the file name ever updates, so does my text..
If you want to create more. You have to create a custom property in the model file itself. Hope I helped..
Matt
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
ctopher's home site
Thanks for your replys.
To be honest - i never read the question i posted....i only copied and pasted it from an email from a mate!!
I will look more into it and see what i can make out form your replies...and i will try and clarify if i can.
thanks again,
Callum
FAQ559-1091
He had asked me directly - due to my lack of "drawing" mode experience I was unable to suggest a solution so asked him to forward me on the "questions" and I told him i would post on here on his behalf!
I will show him the above posts today.
callum
