Assembly Origin
Assembly Origin
How can I change the origin of an assembly?
When I want to do a cut view in the one Im working (extruded 80x30mm tube) I have to move almost 80mm to cut the piece at mid section.
Thanks!
Thanks!
RE: Assembly Origin
RE: Assembly Origin
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
RE: Assembly Origin
You can always add a plane at the point you want to cut.
One of the parts in your assembly probably has a fix contraint. Switch this to float. Now, you can move your assembly about. I strongly suggest you restore the fix contraint when you are done.
JHG
RE: Assembly Origin
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
ctopher's home site
RE: Assembly Origin
There is no need to move origin. Parts and assemblies in real world have neither origin nor "Top/Front/Right" planes. When you do detailing in drawings, you should not touch models.
Alex
RE: Assembly Origin
Chris
ctopher's home site
