Air cooler header box design
Hi all,
I'm new to the mechanical design of air cooler header box and its nozzle.   Is there a code/standard that applies to this type of equipment?
I am guessing here but I think Sect VIII, Div. 1, Appendix 13 for non-circular cross section would be applicable for the header box design.  What about the calculation method for the nozzle to the header box, which industrial method is used?
Thanks.
RE: Air cooler header box design
Start with reading API 661.
Team Member's
API 661/PRO www.paulin.com mechanical design of air cooler header box and its nozzle & the Home of "FE-PIPE"
Thank you Isthill and ijzer for your help.
