Pipe Flow from Resevoir
Hello All,
I am working on a zoo exhibit with a large pond. We will be circulating 250 gallons per minute thru the pond. Water will be drained from the pond at 1/4" per foot back to a holding tank were the pump will be located. The pump will then pump water to a man made creek that will flow back down to the pond. My problem is that I am having a problem sizing the pipe from the pond to the holding tank. The pipe will discharge from the pond 15" below the water surface. Can anyone help me size the pipe from the pond to the holding tank.
RE: Pipe Flow from Resevoir
Howevere I would verify with pipe supplied
http://www.cpp-pipe.com/techpapr.htm#references
