Damper Dilemma...
Damper Dilemma...
I have 2 wood boiler dampers that, based on 4-20mA signal from a pressure controller, operate in unison to control the air moving through the boiler firebox. The dampers are positioned as the 4-20 signal dictates, and their position is fedback from separate 100 ohm "slidewire" resistance devices. Each damper has a separate controller strictly for positioning. I'm convinced there is no device in the world that will replace "only the damper controller" so I have to come up with a plan "B". I have a new controller with slidewire feedback that is using the steam pressure signal. It will control one damper nicely, while monitoring its slidewire feedback...but if I add another controller in the steam pressure loop to control the second damper, they will not operate in unison. I could connect all this up to a PLC and add a couple of displays and switches for position control...but that's expensive. Wondering if anyone has any suggestions on how to make these units operate in unison. Assume there are 2 new separate PID controllers on the steam pressure signal, with a slidewire input from each damper to its respective controller. Thanks!
RE: Damper Dilemma...
Cascade controller tuning guidelines need to be applied.
John
