tubing ridges
tubing ridges
tubing ridges
I'm trying to represent flexible tubing on a drawing and would like to show the ridges using lines perpendicular to the spline. How can I do this without drawing each individual line?
RE: tubing ridges
Try using the MEASURE or DIVIDE commands.  Each one places a block along a line, spline, or pline at certain intervals.  MEASURE places the block at a given distance along the line, DIVIDE breaks up the line into the given number of segments.  You can choose to align the block with the object, which should give you the perpendicular lines you're looking for.
RE: tubing ridges
Another idea: You may be able to change the linetype to one with crosses or slashes.  A custom linetype may be needed though...
RE: tubing ridges
Try offsetting the line and then change its linetype to a  linetype like zigzag (you may need to load it) and see if that gets you close to what you want. Otherwise, you may need to create a new linetype like IFR said.
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: tubing ridges
Thanks everybody, The measure command worked well.
