weld joint calculation
I have a diagonal brace (channel 4"x8"x0.5"thk) working in compression, but for dimensional restrictions for to put inside the painting room we need to cut the brace 10 " away from one end, and after weld again the brace with no plate in middle just channel to channel weld, how can I analize the strehght of the weld?
Thanks.
Thanks.
RE: weld joint calculation
If so don't bother to analyze this attachment - it is a not recommended repair. As a minimum, you would want to install a replacement channel that is full penetration welded to assure adequate strength in tension and compression.
Do yourself a favor and purchase a replacement channel of the original length.
