surface sectioning
surface sectioning
when sectioning a view that has surfaces in the part the sufaces do no cut away? is this possible.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: surface sectioning
There is a sketch tool for converting the entities of items that pierce through your sketch plane called Intersection Curve. Click that tool, then the items that come through your sketch plane, and it will make a sketch entity of the items that pierce your plane where they cross the plane. Helpful for building up loft profiles, etc.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
