LCF curves for steel.
I need help locating textbook LCF curves for A516 and A216 steel. Any grade is acceptable. And any temperature is acceptable.......for the moment.
I have searched and googled all I can, and now it is going to cost $$$ to obtain curves through testing.
Thank you for any help you can provide.
RE: LCF curves for steel.
"Low Cycle Fatigue"
I am assuming there are some sort of curves out there, for steels with virtually the same composition as A516 & A216, that I can obtain for less money then what a 1-2 month long test would cost........some kind of published work with these curves.
Thanks again for any help.
http://www.welding-advisers.com/
I've only got about a day left to find it before we give the "goahead" for the testing....pushing the project completion date back.
Thanks Goahead
