Fatigue weld finish
Fatigue weld finish
Hi
Does ASME VIII Div 2 specify a surface finish and profile for vessels operating in fatigue service? For example fillet welds that are radiussed and circ/long welds that are ground smooth.
OR is there a recognised standard which states or provides samples/photos/etc, by which the weld finish can be inspected for fatigue service?
We are busy inspecting a vessel with a section in fatigue service and would appreciate any input. The quality of the finishing varies, some areas seem exccesively smooth and other areas are too roughly grinded.
RE: Fatigue weld finish
As far as I'm aware, Div. 2 does not specify a surface finish for welds. For fatigue service, there would be no such thing as excessively smooth, and "rough" will be subjective, though I have seen a molded plastic series of sample weld roughnesses. One thing to note though is that fillet welds are lousy in fatigue. I'm hoping that you are referring to a full pen weld with a fillet...
jt
1. Using SCF (Stress concentration factor) to reflect the welds condition;
2. Check with PD5500 or BS EN13445 (British standard for Unfired pressure vessel) for reference.
