Maintaining Relative Humidity Values
We have a drying process where we have to maintain different values of Relative Humidity values in a day. That is, 80% RH from 0900 hrs to 2000 hrs, 60% RH from 2000 hrs to 2300 hrs and 40% RH from 2300 hrs to 0900 hrs. I'm unable to find a humidity controller that can be programmed in this fashion. Can you please mention some specific product for this purpose.
Thank you.
Thank you.
RE: Maintaining Relative Humidity Values
Can you verify for me that this controller will work? Also, this seems to be an expensive device, so any suggestions for a cheaper solution?
I was thinking more of something like the unitary controller ht
You should contact JCI to determine if that product is suitable for your application.
