use of waste hydraulic oil
i want to use waste hydraulic oil to heat a warehouse.has somebody done this ? also if possible to use this oil in a small burner to heat a greenhouse at home ! can a mod be made to existing oil/keresine burner/boiler . what temp does the hyd oil need to burn efficiently etc etc
RE: use of waste hydraulic oil
If you ever notice on a gas pump, the labels say "For use as a motor fuel only"- ie, they don't recommend using it in your Coleman lantern due to the additives in it. Perhaps similar issues here.
Steven van Els
SAvanEls@cq-link.sr
