Shifting linkage adjustment
I had to cut the 2nd gear shift are on the steering wheel, to allow room, for a dual exhust manifold on my 1941 chevy. What can I do too make it shift smoothly again? I have tried all the adjustments. Will cutting the other arm, the same amount, help?
Thanks; Dick Lyon
dplyon@adelphia.net
Thanks; Dick Lyon
dplyon@adelphia.net
RE: Shifting linkage adjustment
what did you cut? OR WAS THE VAC CYL REMOVED IF YOU CUT THE MAIN LEVER AND IT SHIFTS HARD YOU MAY TRY SHORTENING THE ONE ON THE COLOUMN .I BELIEVE I REMEMBER CORRECTLY. I REBUILT MANY OF THEM . THEY DID CHANGE OVER THE YEARS ,MANY REMOVED THE VAC CYL YOU HAD TO LUBE IT AND ADJ IT CORRECTLY AND IT WORKED LIKE A CHARM YOU COULD SHIFT WITH 2 FINGERS
