Wanted: Qualified Tester for VMC
We broke the spindle drive belt on our new VMC when using less than 100% of spindle power. The belt, is under designed if Gate design information is used and the machine has a vibration that starts at about 40% of spindle power. The Z axis gives overload alarms some times and uses 40% of the drive power when under no load with a counter balance.
The dealer will not accept our test of spindle or axis power, so we need someone to do it.
Is there a company that can test spindle torque and axis thrust?
RE: Wanted: Qualified Tester for VMC
Who makes the machine?
Bill
Robert Setree
www.advanced-grinding.com
Robert Setree
If we get results that show the machine does not meet advertised specifications, then we need an independent company to verify our test so we can see a lawyer and sue for false advertising.
I believe many of the machine tool manufactures only calculate the specification and never test them.
Maybe the industry needs a "Consumer Reports" type group to weed out the dealers and manufactures that misrepresent machine tools.
