Tube bending formula
I haven't been able to find a formula for bending square tubing.  Typically we cut a few pieces until we get it right, but there has to be a way to calculate this without going through several stocks of tubing.
For example:
1" square cold-rolled steel tubing
45 degree bend
2 1/2" inside bend radius
leg 1 = 35"
leg 2 = 21 1/2"
Also, a formula for round tubing would be great also.
Flores
RE: Tube bending formula
Not sure about tube but for sheets I always start with
(2/5 thickness + inside rad) x 6.28 =360 degrees and then build in a factor for the material through experimentation, this gives the development for the bend.
So for the example you give
(2.90) x (6.28 / 8) = 2.46” so assuming the lengths of 21 ½ and 35 are flat lengths and not to intersection points the length would be 58.96”
This should give you somewhere to start and from there I would factor in any errors and see how different wall thickness etc change things through experimentation.
The more you refine the closer you will get.
Hope this helps.
Thanks Ajack, but I was hoping  someone had a formula for square tube.  For sheetmetal bend dedcutions, I use Bendworks,
http://www.massey.ac.nz/~odiegel/bendworks/
But, because of the side walls in square tube, Bendworks isn't perfect.  For 90 degree bends, a k-factor of .6035" seems to work pretty good, but I can't find a suitable k-factor that works for all angles.
Flores
