Threaded Pipe Fittings of Different Materials
I have an aluminum filter housing that needs to connect to a pumped drain system made of copper.  When the system is in use, it will operate at about 140F.  Thread size is 2" NPT.
What connection should I make between the two materials?  I'm concerned about threaded joint leakage due to differing expansion coefficients, as well as possible galvanic action.
---KenRad
