Cast Iron Turbine Casing Repair
Can anyone recommend repair options for a 12" long crack on a 4" thick cast iron turbine casing? This 17 ton component is located inside a turbine pit which holds a dual francis horizontal runner/shaft assembly. Will a weld repair be successful if preheat is not possible?
Thanks.
Thanks.
RE: Cast Iron Turbine Casing Repair
We have used the metal stitch mechanical repair method with great success.
KMP04
www.Casting-Repairs.com they can help you.
We are currently in contact with several Cast Iron repair companies that specialize in this service. If all else fails, I may have to fabricate a new casing.
Thanks for the other links and info metengr & teb1.
Anyone know of metal stitch repair companies in Canada?
You haven't called the number on my website or you would be talking to me and we would be solving your problem!
give me a call 204-477-7900 to discuss.
I would recommend you do a net search on METALOK.
This metal stistching technique works extremely well.
The proper spelling is Metalock. It is a registerd trademark that is owned by the original Metalock Corporation in North America with offices in Chicago and Baton Rouge, La.
http://www.inplace.com/machining/metalstitch.html
