Vapour Pressure-Zinc Chloride ZnCl2
I am trying to generate a curve for the vapour pressure of liquid zinc chloride as a function of temperature. If anyone has a reference I would be very greatful. Alternatively if anyone knows the Antoine coefficients for zinc chloride that would help me out.
Thanks in advance,
Thanks in advance,
TISM
RE: Vapour Pressure-Zinc Chloride ZnCl2
melt point 365 oC
1 mmHg @ 428 oC
10 mmHg @ 508 oC
40 mmHg @ 566 oC
100 mmHg @ 610 oC
400 mmHg @ 689 oC
760 mmHg @ 732 oC
A more modern copy of the above reference may give you the coefficients you seek.
42, 481, 536, 584, 648, 689 Celsius, for abs. pressures of
1, 5, 20, 60, 200, 400 mm Hg, respectively.
Melting Point: 290 oC, Boiling Point: 732oC. Mol. Wt.: 136.29.
CAS #: 7646-85-7
