Sealing methods for poly
Can any one suggest me some sources which describe in detail sealing of plastics especially polycarbonate,PMMA,PVC
RE: Sealing methods for poly
Hope that helps.
Solvent welding with methyl ethyl ketone (MEK) or toluene is the most economical. Next least expensive is a hot melt adhesive such as ethylene vinyl acetate (EVA) or ethylene acrylic acid (EAA). The most expensive would be an adhesive such as cyanoacrylate glue.
