Property Line Closed Figures
Is there a way to create a closed property line figure. I am trying to enter individual lines and having trouble getting the figure to close. My original plat measures accurate, but my cad reproduction does not match.
Thank you
Thank you
RE: Property Line Closed Figures
Thank you
You have to command @distance,bearing.
If you just say distance,bearing ACAD will think you want absolute coordinates.
That could be the problem, it is a mistake I have made, oh, about 1,000 times so far.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
@44.5<N42d15'00"W
@110.18<N48d23'10"E
@54<S47d41'00"E
@115.77<S52d56'42"W
When I put the above in Cad the figure does not match my drawing. I drew the figue in Visio and it comes out ok. Any help would be appreciated. Is this a known bug in cad 2000?
1. The original drawing doesn't have north oriented up, or..
2. Your drawing isn't set to have north oriented up. Check Format>>Units>>Direction, select east as the base direction.
Thank you for the help.
