Seeking source of low cost shock mounts for CD type drives
If you have ever had cause to open a ghetto blaster or similar, you will observe that the CD drive is suspended on posts or standoffs with what appear to be moulded shock mounts. They are often like little convoluted bellows, moulded in a soft elastomeric. I'm sure these are available, in qty, at low cost from Asian sources. Has anyone ever sourced these, and if so would you be willing to share that info?
Yes, I know there are high end vibration and shock mounts around, but they are too expensive for the application.
Thanks in advance.
Nigel
Thanks in advance.
Nigel
"The ideal client is one possessed of great good sense and perfect judgement;
that is to say, one who agrees entirely with the designer at all times and in every respect."
Fenwick Williams, Naval Architect.
RE: Seeking source of low cost shock mounts for CD type drives
http://www.earsc.com (Aearo/E.A.R.)
By the way, they make the acoustic tiles used on submarines too...
