odd taper
odd taper
odd taper
I have a request for a taper drive that is unidentified - wondering if anyone knows if its a standard or not.  The angle off the centerline of the taper is 3 degrees 35 minutes and it has a .500 drive tang off the end (end dia approx 1").  Any ideas?
RE: odd taper
If your numbers are correct I would say you have a 1.500 inch per foot taper measured on the diameter. I don't know if that is a standard or not.
RE: odd taper
Thats what I calculated it to as well - we have an older print that almost matches the angle (has a keyway that this design doesn't share) but can't find a reference from any standard it may have come from.  It may just be an odd-ball from the past that has never been changed.
RE: odd taper
Rmetzger,
I'm going to stick my neck out here and say that this is a 7° included angle taper.  From a somewhat limited exposure to these, this is sort of a dividing point between self-locking taper and non-locking.
When I worked with these, we used 7° because the tool would self-lock but took a minimum amount of force to loosen it when changing tools.  In other words, a more shallow taper, say 4-5° included would lock so tightly that you might destroy a drift removing them.  10-12° would almost fall out and so needed some sort of retainer.
Griffy
RE: odd taper
Is this part a sheave or some other rotating part. Its been many years but on combines there were sheave with tapered bores which then had a split sleeve pushed into the taper to lock on a round shaft. I don't remember what the taper was but I made thousands while working for Allis Chalmers.
RE: odd taper
Its an input drive to an engine (transmitting starting torque at around 3000rpm). I haven't gotten all the details of the system yet but I'll post them when I do.
RE: odd taper
rmetzger,
This wonldn't happen to be a rotax or cuyuna engine would it?
Griffy
RE: odd taper
I doubt it, most of the engines that we are designing to are larger (50 liters+) than I think either of those two companies make.
