how to use mathematica NDSolve with BC???
hello
I am working on a project and i came up with an equation (2nd order dif.eq. with bc).I am using mathematica (try to learn) but for some reason i cannot get it to work.
My eguation is similar to the rectangular fin with finite length but i also have radiation.In addition K is a function of temperature and also Tinf changes...for half the fin it is 1000 and for the other half Tinf=25. I am using an If statement for this.
Anybody expert on mathematica can help?
RE: how to use mathematica NDSolve with BC???
thanks...
you are new at the site too ha!!(just joined on friday!!). and you tried to answer my question!!
although i saw what they are doing am not sure it will work for my model.I hope i will find the answer in the books i found online.
thank you very much though....J
