sketch or idea needed
Help... lol kinda out of my depth when it comes to Mechanisms .... thus i need your help
i a sketch of the following
a gear wheel is to joined to a shaft so that it can move along the shaft but not rotate about it... how can this be done?
thanks
thanks
RE: sketch or idea needed
Shaft with a keyway, dog point set screw(s)in gear
Shaft with a key in a keyway (key attached with screws)
Splined shaft, splined hole in gear (many types of spline)
Polygon shaft, polygon hole in gear
You might also consider fixing the gear to the shaft and sliding the shaft in the support bearings instead.
can you give me a more detailed explanation of this
as well as Polygon shaft, polygon hole in gear method
thanks
For the latter, think of a hexagon shaped bar (nut profile) with a gear with a hex hole through the center surrounding it. A bit of clearance will allow it to slide along the length of the bar but the sides on the hex will not allow free rotation. Similar to the idea of a box end wrench - it can easily slide onto a fastener axially but also can provide rotation and torque to the part when turned because of the interference between the shapes.
Sorry I didn't respond immediately - been busy. Actually, although you can certainly do it with a hexagon shaped shaft as rmetzger says, I was actually thinking of the ultimate in cost and sophistication - the rarely seen "Polygon" profile - at one time a trade name - eg see
http://www.generalpolygon.com/index.htm
The classic one of these is a sort of triangular shape with rounded corners - probably approximating a "constant breadth" curve. Among other claimed advantages, it has a self-centering action when torque is applied. In the early days when these first came out, about 40 years ago, I recall a British machine tool manufacturer (I think it was Herbert) who built a large spindle gearbox with all the splined sliding-gear-carrying shafts replaced with these things. Although the promoters claim otherwise, it cost a fortune of course, with apparently very little benefit. You do find them on some engines I believe, on the end of the crankshaft.
