Convergence of Polytropic Compressor Module
Has anybody had difficulty making the polytropic compressor module converge? I have found that the module sometimes just doesn't work properly. In one situation even the support team at winsim had to admit defeat.
If you used a guess value please explain which stream you applied it to, i.e. suction, discharge, or recycle.
Rgds
Rgds
