End Angle for Helix
End Angle for Helix
I have a cooling coil part for which I created a helix. It's revolved 4x and the height is 4.5". I started the helix @ 240 degrees on a face of an existing sweep b/c the first 30 degrees at either end of the coil are a smaller diameter than the rest. This worked fine for the start of the helix ("Start angle. Sets where to start the first turn on the sketched circle." - from Help) Does anyone know how to achieve an "end angle"? There doesn't seem to be a setting for this and SW completes the 4th revolution to end @ 270 degrees. I tried revolve-cut using both a regular sketch and then a 3D sketch with no luck. Has anyone had to do this before? Any suggestions appreciated.
RE: End Angle for Helix
Eng-Tips.com Forum Policies FAQ731-376
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
<http://www.esoxrepublic.com/models/>
Download & examine the file TorsionSpringByTheTick
