UG v18 - Drawing Object Associativity
I'm having trouble editing a drawing in that when I select Edit > Drawing Object Associativity and select a dimension, I get an error message saying "Cannot edit associativity for sketch dimension". What would be causing this and how can it be solved?
Thanks in advance.
Thanks in advance.
RE: UG v18 - Drawing Object Associativity
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Furthermore, when the dimensions were created, I was unable to position them as intended. Boxes added to dimensions would not be applied, and updated existing boxed dimensions gave the error message in my original question.
Is there any possibility that the part/drawing has been corrupted and is there any way of finding out?
Fred
