Opening an Inventor Part in SW
Question for someone with experience working between SW and Inventor.  A customer sent me an Inventor part file and when I try to open it in SW2005, the following shows up in the error file:
          SolidWorks Corporation - INVENTOR Processor Error Log
          ______________________________________________________
                       INVENTOR Post Processor
                       ___________________
INVENTOR File Name: C:\....\Flange.ipt
ACIS error message:
    operation unsuccessful
Error: No solid data in file.
INVENTOR-in did not complete successfully.
Context: Record ending on line number 1
         OR one of its fields.
Anyone have this problem?  Could there be a problem with the file itself?
Matt
RE: Opening an Inventor Part in SW
This isn't something I'm familiar with, but it sounds like there is an error in the file--perhaps it's not a solid volume, but my guess is that there are some holes along the seams of the surfaces--surfaces intersect or have gaps.
Perhaps you can have the file re-exported with different export settings or into a different format and try to import it again.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
I agree. Have Inventor export as IGES, STP, etc. Something SW can import.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
ctopher's home site
MattP ... Yes the Inventor file could be corrupt ... after all it is an AutoDesk product.
However, if it isn't, SW should be able to open an "ipt" file.
Is the Inventor file of a version which SW is able to open? If it's the very latest Inventor version, SW may not be programmed for that.
Have you experimented with the SW "Open" options for "ipt" files?
Eng-Tips.com Forum Policies FAQ731-376
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
I have just learned that the Inventor file in question was of Version 9.0.  Is this the newest release?
I don't know--Google it or something and you should find out what they're promoting.
Jeff Mowry
We've had the best success by exporting data out of Inventor in the .sat file format.
