Drawing file getting large
I don't understand what is going on here- my model is a large, complex casting. It is 24.7 Mb. The drawing for it is 49.7 Mb however. The drawing is 8 D-size sheets and there are about 42 different views and sections.
I know it is large because it takes several minutes at each rebuild and save. I would think the drawing file would be much smaller than the model. The model also rebuilds and saves in seconds rather than minutes.
I understand there is a light version that can be used for email, so maybe it is not an issue, although I will need to email the comlete file so that the end user can modify it.
If I am doing evertything right, then I will see what more ram will do.
RE: Drawing file getting large
John
