Rotate a drawing using VBA
Can anyone tell me how to get the maximum height and width of the actual drawing objects in a DWG? I have several drawings that are rotated 90degrees from the usual position in order to facillitate an older printing program. I want to write a program that compares the height of the drawing to the width and, If the drawing is taller than it is wide  rotates the drawing by 90Degrees. anyone have any idea how to do this?
