Need concrete storage pond design references
Client has requested concrete storage ponds to retain contaminated storm water at an industrial site in the far north. The ponds are small (300m^3). I need a design reference. The PCA and CPCA websites did not have references listed in their online libraries. Is that because concrete is not used for this application?
Any comments will be helpful. Particularly canadian ones.
RE: Need concrete storage pond design references
You did not state if this is going to be in or above ground pond.
PCA used to publish a rectangular and round concrete tank design guides. I suggest that you get a hold of one to help you in the design. If it is in ground, then it can be designed as a simple retaining wall. The worst case is when the pond is empty. If it is above ground, the analogy of retaining all applies with the worst case is when it is full with fluids. Of course one must not forget other loads as they apply such as wind and seismic loads as applicable.
I would also consider some form of interior coating or a liner system for the pond. There are products out there that are spray on, or mopped on as well. These products have varying chemical resistance. Many of them are elastomeric which make them bridge hairline cracks as they develop in the concrete.
One such company that I have used in the past is FUTURA. Here is a link to their web site: http://www.futuracoatings.com/
Lutfi
www.cdeco.com
regards
sc
