Translating solid parts from Pro/e to AutoCAD
I use pro-e but I need to be able to provide solids that can be imported into AutoCAD. Would someone instruct me in the procedure for the part translation. I have AutoCAD installed but never use it. When I launch AutoCAD I've looked to see if it will import .igs but I've not found a way (in Acad) to import a solid part. Any suggestions?
SrGilberto
SrGilberto
RE: Translating solid parts from Pro/e to AutoCAD
Best Regards,
Heckler
"Never underestimate the power of very stupid people in large groups" John Kenneth Galbraith
When you import the iges in autocad reads it as a wireframe model. If i want to convert it back to a solid 3-d model in autocad , i have to use the mechanical desktop commands to recontruct the model. On complex part its just not worth the time. It may have changed in the newer releases of MDT. I use ver5, and i think ver 7 was the last release.
Best Regards,
Heckler
