Powering a DC motor with AC
What would you suggest as the most cost effective and space efficient way to run a 24v 10amp dc motor with 110v AC. Must be as portable as a cord will allow. An 8lb transformer with bridge rectifier isn't feasible, any other words of wisdom.
RE: Powering a DC motor with AC
1. A single SCR with a gate control that turns on pretty late in a cycle, limiting the applied voltage. You'd probably need an 8 lb flywheel to integrate the choppy torque, and you'd never get near rated torque, but it would 'run'.
2. A high frequency switching supply with 24VDC/10A output.
3. Do you really need full voltage and full current? Switchers get smaller and lighter if you don't need both. You didn't specify a load on the mechanical side.
Did you need variable speed? That costs extra.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
Any switching power supply's I've come accross are rated in watts and one of this size is from $300-$1000. Am I barking up the wrong tree?
You can control the speed by using a separate single 5K turn pot (one comes with it) or an isolated 0 - 10 VDC signal.
Unfortunately, you can't access the specific model, but the series is shown, along with locations you can call.
I have used these drives on 1/2 HP, 50 VDC motors, and found them to work quite well.
BK
http://www.kbelectronics.com/catalog_chassis.htm
"Venditori de oleum-vipera non vigere excordis populi"
