Re:Copper clad on 416 steel
We have a torquer ring that goes in a vertical displacement gyro unit, the ring is made of 416 steel with a copper clad that is plasma sprayed on the front surface. the ring is a left/right directional type that is driven by the torque coil magnetic field. My first question is, What is the purpose of the copper cladding on the ring and the next question is that we now have some rings that do not have the magnetic properties (very weak) that previous rings had, some how the vendor has changed the process or material, can anyone that give me insite on what is going on?
RE: Re:Copper clad on 416 steel
The copper clading (especially if reasonably thick) could be used for eddy current damping.
