Lean buring a Natural Gas powered Reciprocating engine
Does anyone know who can help me convert a Natural Gas powered Reciprocating Engine into a lean burning engine to reduce the emissions? I have a old Caterpillar engine that produces substantial amounts of NOx and CO and I need to reduce the emission in the area without replacing the whole engine with a newer model. What other economical methods could be used to achieve this?
Gavin Tweedie
Gavin Tweedie
RE: Lean buring a Natural Gas powered Reciprocating engine
Cheers
Greg Locock
1. Power will be reduced roughly in the proportion you reduce the fuel/air ratio, unless you can increase the air flow e.g. by increasing boost pressure, assuming the engine is already turbocharged. This would necessitate investigation of the turbocharger capability. If not turbocharged, turbocharging could be added, but that would not be a small undertaking.
2. You have to go quite lean (50% excess air or more, typically) to see a significant NOx benefit. This will put the engine near the lean misfire limit, so fuel control needs to be very accurate to keep it a zone where NOx is low and simultaneously there is adequate margin against misfire. The only two ways to ensure that the engine continues to operate in this zone over time, given component wear/drift, and variation in fuel composition, is to check and readjust the mixture controlling hardware regularly using appropriate instrumentation to verify the air/fuel ratio, or use a closed-loop fuel control system. You may find there are aftermarket kits of this type for lean burn, but they will be pricey.
I would suggest you contact the local parts & service support outlet for your engine to find out what is available for converting it to lean burn. If you don't know of one in your area, try Hatch & Kirk (http://www.hatchkirk.com/).
You could also go to Impco Technologies (a manufacturer) website (www.impco.ws), and follow links to their distributors.
With natural gas, you should be able to get good CO by accurate adjustment to stoic.
Maybe water injection will reduce your NOx emissions for little cost and risk. Note, I say little, not no risk.
pat pprimmer@acay.com.au
5.6L OHV engine running at stoich, exhaust outlet temps 1250 deg F. At L=1.3, at 20 lbs turbo boost, the temp drops to 970 deg F. It is possible to run a non boosted in lean mode but at a substantial power reduction. To make it most effective it must be turbocharged.
That same engine made 450 lbft torque at 3,000 rpm at L=1.4 at 30 lbs boost.
I have seen more damage caused by rich fuel mixtures in gaseous fuel engines than with lean mixtures.
Lean burn mode is almost the exclusive rein with gaseous fuels due to its requirement for a fully homogenized air-fuel mixture. Its difficult with gasoline because the small gasoline droplets tend to clump while the relatively even distribution of NG or LPG supports a more even flame propogation.
Today, just controlling CO with a good tight AF contol is possible, but at a cost in NOx. Aftertreatments help but a precise AF control is mandatory. Water injection lowers combustion temps, but like my illustrious colleague Pat states, there is some risk of a hydraulic lock engine.
Franz
Check your emissions now, if your near Stoich or a phi slightly rich, you should see around 4500ppm CO and 3000ppm Nox. If your in the ballpark, put a Bandito Johnson Matthey CAT on it - it will knock it down to less than 250ppm CO and less than 100ppm Nox. (assuming your valve seals are good and carburation and timing is stable)
Best
John
Catalytic converters
A lean burn engine is a ground up proposition. Pistons, heads, everything is new.
It has been done, and can be done. Do you want to pay for it. You will probably need to get a turbo as you need to force the air into the cylinders to maintain your HP ratings. Plus you will gain more scavaging and cooling effect, depending on your valve overlap. The Superiors had different cooling rates for the lean burn units.
Cat may have a convertion kit. I would say that a catalytic converter is more cost effective. However the elements are not cheap, and maintianing an A/F controller that keeps the Cat burning is sometimes tricky. (we made our own, and learned the hard way)
Miratech is good, so is Johnson Matthey.
http://www.miratechcorp.com
http://www.jmcsd.com/catalytic_converters.html
Good Luck,
dwedel
Hotrod Big Engines!
For site policies and guidelines
see FAQ731-376
Make sure you price out the cost of replacing the converter elements every one to two years. If you have backfiring problems, you will want to fix them, the first time you destroy the converter elements.
dwedel
Hotrod Big Engines!
see FAQ731-376
Just one more thought.
dwedel
Hotrod Big Engines!
see FAQ731-376
