bend table -"other" angles
I saw a similar question posed in an earlier thread, but no answer.  Does anyone know if there is a way to include other angles in the bend tables?  I'd like to be able to add bend deduction numbers for angles other than 90.
RE: bend table -"other" angles
Quote (SW_help_files):
If the thickness of the part or bend angle falls between values in the table, the software interpolates the values to calculate the bend allowance.
Eng-Tips.com Forum Policies FAQ731-376
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
As CorBlimeyLimey said, just work your way back using the concept of ratio! It works!
